Questions on 5 axial processing in Fusion360
millermaho
millermaho
Are there any people on the forum who are versed in the 5 Axis (Multi Axis) processing in Fusion? Question: In the Flow and Swarf strategy, after postprocessing, the code with normal vectors (LN, TX, TY, TZ) is output, how to specify the movements with the rotation axes, and not the tool orientation? Or to dig a postprocessor? Stand Heidenhain530.
AchimN
This is because the post processor does not know your machine kinematics, so we output 5x movements as normal vectors for the heidenhain. If you like to see machine angles instead, you have to specify your kinematics into the post as described here:
How to set up a 4/5 axis machine configuration
Achim.N
Principal Technology Consultant
GeorgeRoberts
Good Morning,
Thanks for posting. Vectors are usually used when no machine configuration has been added to the post processor. To be able to have machine angles output, you need to add a machine configuration to the post, this will give the post the information needed to calculate the machine angles for your specific machine.
For information on setting up a machine configuration for your post, please visit >>this post<<
Hope this helps
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
millermaho
Thank you all for
help, I will configure the postprocessor. With the results I will write here.
millermaho
Thank you for your help, article on setting up the post-processor, helped, set up the kinematics of your machine.
Now the control program is displayed with rotation axes.
