Question regarding the strategy and parameters to use a circular saw for roughing out stone
rajis.kataria
rajis.kataria
I am currently using fusion to program a 5 axis bridge saw for milling 3axis. Here below are a few pictures of the results using only a stone milling cutter.
The process takes much time, so the idea is to cut parallel slots using the circular saw with 20mm spacing between each pass; I would leave enough stock and hammer down the walls (like seen in the last two pictures I put for illustration).
I would like the saw to plunge only 2-3cm at a time and also follow the profile of the model once reaching the final step downs.
Im having a specially hard time following the contour of a sculpted 3d model that has many complex shapes and vertices.
How would one proceed using fusion cam? Any tip or suggestion is greatly appreciated.
Kind regards,
Rajis
circular saw view.jpgstone milling.jpg90B75DBC-DAE4-4885-81C3-93D1699E3BBB_1_102_o.jpeg3C92B862-BD15-413A-9552-D9974BB8682A_1_105_c.jpeg257E485D-79A6-43BB-AC0C-9F1D27F0B532_4_5005_c.jpegAC0FE3A5-8D67-442F-84C5-2A15C8967131_4_5005_c.jpeg
Warmingup1953
Are you using a specific post processor?
rajis.kataria
@Warmingup1953
mach3mill post pro seems to do the trick this far, i only change g54 to g154 and add G64 for continuous movement. What do you have in mind if I may ask?
rajis.kataria
mach3mill post pro seems to do the trick this far, i only change g54 to g154 and add G64 for continuous movement. What do you have in mind if I may ask? @Warmingup1953
Warmingup1953
For me it was just a thought bubble because I had seen a Youtube  with a saw in use albeit a simpler task... I'll link here but I fear it may be on the wrong track as you'd need 3D paths. It is a bit frustrating to watch but I think it does (Eventually) demonstrate swapping the Axis that is needed.
https://youtu.be/I1UGUHS5W5U?si=DxbrihguOfeLYrNg
a.laasW8M6T
Hi
I have an idea using Steep n shallow.
You cannot create passes greater then the Flute length(Saw thickness) so say its a 4mm saw, you set the stepdown to 4mm and you get a toolpath like this
Then using delete passes
select every 5th line
then invert the selection and delete all the other passes
This should follow all the 3d contours of the part while making the slices
