Fusion Manufacture
Question on Manufacturing imported STEP files
3 REPLIES 3
juan_solisra
159 Views, 3 Replies
Question.
I import a STEP file and want to see about manufacturing it in a Mill CNC (3 axis) process.  When I create the G-code, the radii come in as flat lines.  Is there a way to either import the STEP file with radii intact or a way to modify the file to make Fusion know that it is a radii?
Thank you in advance.
3 REPLIES 3
DarthBane55
in reply to: juan_solisra
Hi, when you measure this radius, does it give a radius dimension?  If yes, then the operation you are coding is a 2d or 3d operation?  Most 3d operations will consider everything a surface, 2d should see it's an arc and output as such.
Usually Step files come in correctly, check by measuring the radius.
juan_solisra
I am using 2D profile and the code is generating as:
G1 Z0.0394 F60.
Z-0.4349
X1.3153 Y-0.7187 Z-0.4395
X1.3151 Y-0.7179 Z-0.4439
X1.3148 Y-0.7166 Z-0.4482
X1.3143 Y-0.7148 Z-0.4524
juan_solisra
Never mind, I looked ahead of the code and everything is correct. I was missing the Z move which is contouring down.
