Fusion Manufacture
pull bar out of spindle
7 REPLIES 7
Message 1 of 8
thierry924K4
350 Views, 7 Replies
Hi Everybody
I need to make a bit of a long piece, the bar is 150mm with a diameter of 42mm. it shakes a bit plus I need to internal turning and threading, this will not work. it shakes to much.
I there a way that I can make the internal work with the piece only sticking out for 60mm then the subspindle comes out and pull it out to 160mm and then I want to cut it.
to work the other side I will turn the piece around manually
7 REPLIES 7
Message 2 of 8
engineguy
in reply to: thierry924K4
@thierry924K4
Does the "Part Handling" function not do this for you ?
It will move to position and clamp to the workpiece using the "Sub Spindle Grab" command and then using the "Sub Spindle Return" to unclamp the Primary Spindle and move away to the position of you choice ??
The actual code output will depend on your Post Processor.
Message 3 of 8
thierry924K4
in reply to: engineguy
Hi, yes but i do not know where i can set the value it needs to go back to?
And after that i need to do another subspindle return?
Message 4 of 8
thierry924K4
@engineguy
Message 5 of 8
ltomuta
Try "keep both clamped" and give the pull distance as the offset in the Feed Plane below
Then a 2nd Subspindle Return command with an offset of 0 will likely send your subspindle home.
Message 6 of 8
thierry924K4
in reply to: ltomuta
hi thx
How would it work if we keep both clamps closed? 🙂
Message 7 of 8
thierry924K4
Never mind I tried it and it outputted this code, wich I think it should work,
I will try this this evening 🙂
Message 8 of 8
marshallt179
You will likely need to compensate the length on all toolpaths after the bar pull. You could probably accomplish this by creating a new setup with a different WCS. As previously mentioned, leaving the Subspindle Return Feed Plane offset at 0 will force the subspindle to return to home (At least that is the case in the post that I am using). There is a new feature for a bar pull that I believe automatically compensates the toolpaths that occur after it.
Here is a link to a bar pull work flow that I have used with the legacy subspindle return strategy. https://forums.autodesk.com/t5/fusion-manufacture/subspindle-workflow-pull-bar-before-parting-off-fo...
This thread discusses the post modifications required to utilize the new Bar Pull feature. https://forums.autodesk.com/t5/fusion-manufacture/post-does-not-support-bar-pull/m-p/12667732/highli...
