Fusion Manufacture
Program Name and description (HAAS-Next Generation Control)
1 REPLY 1
Mike_mPYS8F
71 Views, 1 Reply
I have a program that has multiple setup's.  I can added program number and description to setup #1 but when I generate the G-code (post process), I select the highest 'setup' which includes all the setup's I use.  However, I cannot find a way to save the program number and description so the post processer automatically writes these values in.
Is there a way to add the program name and description to the highest level setup or do I have to manually add it every time I post?
1 REPLY 1
a.laasW8M6T
in reply to: Mike_mPYS8F
Create an NC Program containing all the setups you want to post
Then Write your program name etc here
then every time you post process the NC program it will use that information
