Fusion Manufacture
Problems in turning cam cutting 2 faces
6 REPLIES 6
Matthew.heaton92
189 Views, 6 Replies
I am trying to program this part and am having tons of issues. Almost every part I do I face, then rough, and when i finish I come down the face then the body. That is what I cant figure out how to do. Same thing with the bore. The bore has a 75 Degree chamfer on it but i cant figure out how to cut the bore and chamfer in one finish pass. Any help would be great.
6 REPLIES 6
Please make a demo file with your best attempts at creating these toolpaths and share here as an f3d file.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
I got the bore to work out. but I still cant get the finish to turn the face and the chamfer. This part is after heat treat and all I have to finish is the Overall length and the bore. Here is the file
@Matthew.heaton92 try setting your front mode to stock front instead of model front in the geometry tab.
Akash Kamoolkar
Software Development Manager
I cant believe it was that simple thank you. I was sitting here so frustrated. Thanks again!
@Matthew.heaton92 i'm glad it was that simple. funny thing is, this is the second time this week that someone got this clarified on the forum.
Akash Kamoolkar
**** I need to search better before I post.
