Fusion Manufacture
Problems in generating ramp processing toolpaths
4 REPLIES 4
loveluckey
172 Views, 4 Replies
I am trying to engrave text with a depth of 0.3mm using an end mill with a diameter of 0.1mm. The problem is that the end mill is too small to create a ramp when cutting the text. While the tracing function can cut along the centerline of the text, it does not have a ramping feature. On the other hand, the contouring feature has a ramping feature, but it does not have a toolpath that follows the centerline of the text, so I have to manually sketch the entire text by moving the toolpath by the diameter of the tool. Is it possible to update the program to address this issue?
4 REPLIES 4
seth.madore
in reply to: loveluckey
Please share your Fusion file here.
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
loveluckey
in reply to: seth.madore
add file..
seth.madore
Hmm. I'm not thinking of a possible solution that doesn't some level of sketches. Slot could work, if all contours were equally spaced apart (they're not). 2D Engrave would require a chamfer type tool, but that does support multiple stepdowns (not ramp though)..
Seth Madore
DarthBane55
In 2dContour, if you turn compensation off, it will go on centerline just like trace.
