Fusion Manufacture
Problem with template.
1 REPLY 1
HughesTooling
86 Views, 1 Reply
I have a template I've used for years for machining runners in moulds. When I tried to use it today the leads didn't generate correctly. I have it setup with plunge and no contacted.
This is how it should work.
And this is what I get now.
I spent ages trying to get it to work and eventually used an old design an did a compare and edit and found the problem is that the op was set to 5 axis. @seth.madore seem to remember someone else reporting a similar problem? Is this a bug or do I need to edit my templates? If it's a bug any idea of when it'll get fixed?
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
1 REPLY 1
seth.madore
in reply to: HughesTooling
Yes, this is a bug that was reported in early August, we've fixed it internally and you should see expected behavior in the next release.
Seth Madore
