Announcements
Problem with profile selection in 2D contour
Can someone help with my problem?
I am making gear profiles for milling out of flat sheet. When I try to select the outside profile of the gear in CAM the results are inconsistent.
if the tooth count is below 32 teeth the face profile can be selected and a tool path generated. when I try to do the same with models of gears with higher numbers of teeth I cannot pick the profile. Instead the program insists on selecting faces: the flanks of the teeth or the root and tip faces. All the models of the different size gears are constructed in exactly the same manner. the only difference being the number of teeth and the diameter.
One thing I have noticed is that with pinions of 8 and 10 teeth the profile is very easy to select. As the number of teeth increase the selection becomes harder, with the required profile flickering in and out of highlight with small movements of the cursor, until eventually becoming impossible.
Any help would be appreciated,
Frank
Steinwerks
This is almost certainly going to require a test file or two. Could you attach a .F3D file of one of the parts that are being difficult, preferably with a CAM setup organized the way you would want to machine it?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
HughesTooling
If the gears are extruded in Fusion from a sketch you can unhide the sketch and use that for your path.
Mark
Just did a quick test using a gear generated with one of Fusion's gear scripts and I think I see the problem. Here's a screencast demonstrating how to modify Fusion's selection.
Mark Hughes
Owner, Hughes Tooling
