Announcements
Problem with Lathe roughing not using outer radius of stock
sstephe1622
sstephe1622
Any one else have an issue were the lathe roughing will not use the settings in outer radius?
Replies (11)
akash.kamoolkar
@sstephe1622 Can you attach your file here so i can take a look at it
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
sstephe1622
Look at "Lathe Back" roughing operation.  I tried increasing the stock size in setup.  I also tried changing clearance and outer radius with the same result.
akash.kamoolkar
@sstephe1622
This problem was fixed a while ago. Are you using the latest Fusion release?
Akash Kamoolkar
I don't see any problems with settings in right place.
sstephe1622
Yeah using the latest release.
akash.kamoolkar
@sstephe1622
I too regenerated the toolpath in the file you sent me in the latest Fusion update and I am not seeing the issue. It's machining the correct area.
Akash Kamoolkar
Akash Kamoolkar
sstephe1622
When I load you file the tool path comes in as you have it on screen.  But when I regenerate the tool path it comes in ignoring the stock.  See attached screen shots....Does this mean something in Fusion360 didn't get updated and I should reinstall?
It appears that problem is with your computer or installation of Fusion and not Fusion itself.
sstephe1622
VicKosta sent me a file that shows the correct tool path.  But when I regenerate on my end using his file it ignores that stock....Here is a screen shot of the file VicKosta supplied me after I regenerated the tool path.  Could it be that what ever got fixed didn't get updated on my system and that is why I'm having the problem?
akash.kamoolkar
@sstephe1622
close your fusion and restart it. If that doesn't work restart your computer. Try this to see if it works otherwise uninstall and reinstall Fusion.
Akash Kamoolkar
Akash Kamoolkar
sstephe1622
I uninstalled and reinstalled Fusion360 but still get the same result.  But if I create a new roughing tool path I get the desired tool path...Any idea's?
