Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Manufacture
problem with haas lathe milling with c axis
1 REPLY 1
hbosYHPY6
107 Views, 1 Reply
hello,
I have a question about milling on a Haas ST20Y lathe. When I want to mill a gear with the y axis, it goes well with the first tooth. After milling the first tooth, the milling cutter goes back to its starting position, and the main spindle suddenly starts to rotate 360 ​​degrees and then comes to the starting point of the next tooth. This rotating movement of the main spindle costs extra time. Can I turn a function on or off when posting my program to prevent this, so that the spindle does not continue to rotate?
1 REPLY 1
In the Post Processor properties, there is the
Optimize C-axis selection
Option. Turn this on, and you should be good to go.
This makes it harder to start at any operation halfway through the program, but indeed it saves a lot of time in some cases.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
