Fusion Manufacture
Problem with Fusion360 and Mach3
2 REPLIES 2
ironbornemotorcycles
99 Views, 2 Replies
Hi Guys, I'm having a problem with Fusion 360 and Mach3.
In practice it's been a while since I created the machine file for my cnc.. yesterday while I was creating a new file to make a writing engraved on aluminum I went to upload it to mach3 and in practice it no longer uploads the file..
I select it from the folder but then nothing happens..
I load the same file on Mach4 and it works there and I see the paths. Has this happened to anyone by any chance??
The only thing I can say is that Fusio made me update the machine in the library saying that the one I had was old, so I inserted a generic 3-axis CNC then I gave him the Post of MAch3mill.cps, I also made others try creating other machines if that's the problem.. but nothing.. Do you have any advice?? Thank you 1000!
2 REPLIES 2
Problem solving
Have you tried creating g-code with no machine selected? You should be able to just create a Setup, some toolpaths and post code with the Mach3 (or Mach4) post processor.
Seth Madore
