Fusion Manufacture
Problem with axial grooving
8 REPLIES 8
Message 1 of 9
brane421
400 Views, 8 Replies
I have few problems wit using Fusion, I trhink it is after last update.
One of them is when I use tool for inner turning and groving is not allowed in my setup, it stil makes axial grooving.
Second is in same setub when using tool which I usualy use for axial turning it looks like it takes setup from another setup, not the one I am working at
Did someone had any similar issues?
regards,
Branimir
8 REPLIES 8
Message 2 of 9
seth.madore
in reply to: brane421
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
Message 3 of 9
The lack of any replys to grooving threads shows autodesk know about this issue just wont talk about it im assuming due to liability
Message 4 of 9
Hardly that 😉
We're well aware of the issues surrounding our current Groove toolpath, which is why we've devoted a large chunk of resources to designing a more robust solution for groove roughing and finishing.
Seth Madore
Message 5 of 9
brane421
in reply to: seth.madore
hello Seth, I am sending file
Message 6 of 9
brane421
I am stuck, I cant groove it, any help?
Message 7 of 9
akash.kamoolkar
@brane421 I have created a ticket to fix this issue. until we fix it a temporary workaround appears to be to uncheck "spun profile" in preferences-> optional features. then open and close the setup dialog and regenerate the toolpath. the tool will not go into the groove.
Akash Kamoolkar
Software Development Manager
Message 8 of 9
seth.madore
@brane421,
what exactly do you mean by the following:
1) "in same setup when using tool which I usualy use for axial turning it looks like it takes setup from another setup"
and
2) for your initial issue, which exact toolpath were you referring to, can you provide some screenshots to help us out?
Seth Madore
Message 9 of 9
akash.kamoolkar
@brane421 This issue has been fixed in the Fusion update that recently went out.
Akash Kamoolkar
