Problem with 3D Adaptive Clearing leaves a ridge
Jim-Nolan
Message 1 of 9
Jim-Nolan
Any ideas why there is this small island of material left on the face of three out of the four blocks ?
Replies (8)
Message 2 of 9
angelo.juras
Hello @Jim-Nolan,
Have you tried changing 'Optimal Load' on the passes tab?
Feel free to attach your file and we can take a look.
Message 3 of 9
Jim-Nolan
I am not clear why that would affect the cut, its set on my normal 20%. I have attached the file in question.
Jim
Message 4 of 9
HughesTooling
@Jim-Nolan I noticed you selected a ripper for the adaptive cut, they can have what's equivalent to a small rad on the corner so that can be a problem. Is it a course or fine ripper, might be worth setting it up as a Bullnose and a 0.5 - 1.0mm corner rad but you'll need to be careful not to set it too big or it might remove too much material on the angled parts.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 9
Jim-Nolan
Good point its a YG V7 X-speed rougher and it has a 0.5mm rad on the corner. Although if that was the problem I am not clear why it occurred on three of the blocks not all four. The tool paths look identical.
Message 6 of 9
Steinwerks
Chipped insert?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 7 of 9
Jim-Nolan
No its not a insert tool .
Message 8 of 9
Jim-Nolan
The jobs done now and cleaned up with a rub of the file. So next time I will try with the correct corner rad added.
Message 9 of 9
M&GToolWorks
I have run into this many times with the roughers I use. They have a chamfer.
It would be VERY NICE if you could add a Chamfer to endmills.
