Fusion Manufacture
Problem with 3018 not running since fusion update.
2 REPLIES 2
brettspencer02
100 Views, 2 Replies
Set up as normal, click send (using candle) Z axis moves up contacts limit switch, alarm alert activated , everything stops.
Message: reset required and carried out. Get a message: $10000>error 9. $10000 ok. Have checked limit switches, all good, machine 'home' works. Machine was working well until the resent update of Fusion 360.
2 REPLIES 2
Are you using a static post processor, or are you using a post processor from the generic library? What post processor are you using?
Seth Madore
Using a Cronos post processor with grbl 1.1f. System was working well until the last two fusion updates.
Have tried using and older designed component, with the same result.
