Fusion Manufacture
problem in fabrication mode not following toolpath perfectly
5 REPLIES 5
AJ_Hubbard
157 Views, 5 Replies
so I have been having problems with the tool path in fabrications mode with 2d profile laser head not all the lines are being followed anyone got any ideas
5 REPLIES 5
seth.madore
in reply to: AJ_Hubbard
Could you share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
AJ_Hubbard
in reply to: seth.madore
sure will do thank you
seth.madore
So, good news and bad news..
The bad: this is likely being caused by the geometry that you imported. What was the source of the file?
The good: If we create a new sketch and project all the geometry onto it (a long tedious task), we get toolpaths that are perfect:
Seth Madore
AJ_Hubbard
so the source of the fill is a customers DXF they sent over.
how would you recommend projecting it onto a new sketch?
seth.madore
Did you take a look at the file I shared in my response above? I've done the work for you 🙂
To answer your question specifically; create Sketch, press "P" for Project, select all the curves, click OK.
Seth Madore
