probing ?
probing ?
I noticed that there is a probing option in the drill op , at least with my post I am not getting  any g-code output .
I am curious as to the output code and use . I am starting to look at probing with my flachcut controller , but from the looks of it I maybe better off with mach4 .
Replies (7)
daniel_lyall
with Mach4 you can call Macro's to do your probeing. you may well be able to get your post changes to do this as well.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
I downloaded the demo and  it looks a lot better than what I have now . It is hard to put a few grand of hardware on a shelf and go buy new stuff but a controller over Ethernet is looking good .
I am not sure if fusion probing is a just going to probe in the z or if thare going to add more to  it .
daniel_lyall
yer M4 is not there yet but it is a tickel better than M3, and you can use a pokeys board there are more than one control option you can run them with them.
I think you can get something added to you post to do certain thing's at certain places in you code calls added that sort of thing
Daniel Lyall
The Big Boss
Mach3 User
good to know .. I was looking at pokeys and asked a reseller about them . I was told they are awkward to wire and really didn't see to many people talking about them . not like smooth stepper .
are you running them ?
daniel_lyall
I have a ESS on one machine the other one I will be adding pokey to it. So I can run M4 and another program the one with the ESS I may change to a pokeys as well
Daniel Lyall
The Big Boss
Mach3 User
I see that ess has a faster pulse speed then the pokeys . let me know how it works out for you please.
o.winkens
what changes need to be made in the post?
Thanks a lot
Best Regards
Olli
