Probing Routine Causing Issues In Program
JHarknessX8ZAF
JHarknessX8ZAF
So this issue isn't necessarily related to Fusion 360, but more of a code issue I'm having. I have a part I'm making in a Haas VF-4 (NGC) with a 4th Axis (A) rotary. I cant post the part/file but I think my question can be answered without it.
My programming and post come from Fusion. Using NGC post w/ A-Axis reversed. Part is a cylinder with domed top, stood straight up. Starts with A @ 0deg and all of the work I'm doing is at A90. or A-90. with a lot of back and forth between the two.
Now my issue, I'm using a hand written probing routine at the start to probe both center and top of my part, I am using G254 in the program. Running my program as is, with probing, my whole part is shifted off center in Y axis by .02", If I skip past the probing and start at my first tool and let it eat from there, I get a good part. So, what am I missing with the probing that's causing an issue?
Here is the probing routine and start of the first cutting tool.
G90 G94 G17
G20
G53 G0 Z0.
G53 X-30. Z0
(T25 - PROBE)
T25 M6
G54 G0 G90 A0
G54 G0 G90 G94 X0 Y0
G43 Z1. H25
G1 Z.25 F50.
G65 P9995 W54. A11. D2. E-1.5 H0. I0.
G0 X0 Y0 Z1.
G1 Z.25 F50.
G65 P9995 W54. A20. H-0.5
G0 Z1.
G53 X-30. Z0.
(Adaptive7)
T1 M6
S4584 M3
G54
G53 G0 Y0.
G0 A90.
G254
M8
G0 X1.1524 Y2.0708
G43 Z1.6 H1
T2
G0 Z1.2
Sorry for the long post, any ideas on what's going on would be greatly appreciated!
-James
JHarknessX8ZAF
Please disregard, problem turned out to be unrelated.
