Fusion Manufacture
Probing direction X+ or X-
1 REPLY 1
v.tsybulnyk
155 Views, 1 Reply
Hi guys,
Can somebody helping me with finding right code how I can post Probing X- or X+ direction
Because i need a different code on Fanuc
G65 P9728 D2. J1. Q1. ;  Probe in X- Direction
G65 P9728 D1. J1. Q1. ;  Probe in X+ Direction
Now its posting every time only D1....
But i dont know how i kan change it to ( IF probe direction X- Set code D2/ IF probe direction X+ Set code D1)
This is my post code now
case "probing-x":        //MAKINO V56 OK
protectedProbeMove(cycle, x, y, z - cycle.depth);
writeBlock(
gFormat.format(65), "P" + 9728,
 "D" + xyzFormat.format(1),
"H" + xyzFormat.format(x + approach(cycle.approach1) * (cycle.probeClearance + tool.diameter / 2)),   //"X" + xyzFormat.format(x + approach(cycle.approach1) * (cycle.probeClearance + tool.diameter / 2)),
 "J" + probeWCSFormat.format(probeOutputWorkOffset > 6 ? (probeOutputWorkOffset - 6 + 100) : probeOutputWorkOffset),  //Nulpunt overschrijven
"Q" + xyzFormat.format(1),        //"Q" + xyzFormat.format(cycle.probeOvertravel),
getProbingArguments(cycle, false)
      break;
Thank you
Tags (2)
1 REPLY 1
v.tsybulnyk
in reply to: v.tsybulnyk
In the meantime I found a solution ☺
