I am machining a part as shown in the image below (only 1 instance of stock is shown, but I actually run 4 pieces at a time). I have previously had the WCS origin located on the corner of the stock as shown. This allows me to have only 1 setup in cam with Multiple WCS selected. I can have as many pieces of stock held in the machine as I wish, all with their own WCS. When I want to update the program, I only have to update the one setup and it will apply to all WCS locations. The only drawback to this is that I must probe each new stock location by hand in the machine.
The other method Would be to move the WCS to a known point in the machine and use the "Override Driving WCS" function , which would allow me to use the cam driven probing to find each stock location, as long as it is modeled in my cam correctly, and set the new WCS. The main drawback here is that each new WCS will need to have it's own setup in the cam as they are located in different locations with respect to the driving WCS. This means that If I have 4 pieces of stock in the machine, I will need to have 4 different cam setups for each ( setup for g55 location, setup for G56 location, ECT.) This becomes annoying when I want to make a quick change to the program and now have to make the update within each setup.
Is there a way to drive the probe based on a known point WCS (Such as the one in the picture above), but set a new WCS in a different location such as the corner of the stock?
I am trying to find a way to still have only one NC setup using the "multiple wcs" functionality, but also be able to drive the probe to automatically set each new wcs.
Thanks for any suggestions, Hopefully this makes sense as it was difficult to explain.
