- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to probe a component to set a WCS, but I can't seem to manipulate the position of where it probes.
Once upon a time there was a check box you could select to make the tool probe at the selected point, but now it is always defaulting to only probing to the centre of the feature.
In my attached file, I want to probe against a vertical leg, but it only lets me probe to the centre of the part.
If I change the probing type from Y-Wall to Y-Surface, It will allow me to use the selected point.
This is no good to me as I need these features to be in the centre of the part, not from one edge.
Fusion
