probe an internal tapered ID
Looking to check a mold vs print for wear. imagine a stacked dixie cup, need to measure the internal tapered ID of the cup as the mold and then the external tapered OD as the force.
seth.madore
Sadly, not readily possible inside of Fusion.
You "could" probe a couple diameters and run some math, but it's not going to be a readily acheived workflow. To have Fusion probe the diameter, you would need to construct "imaginary" (exist only for the purpose of diving probes) cyclinders at appropriate heights.
Seth Madore
