Fusion Manufacture
Print settings
5 REPLIES 5
mac_ito
151 Views, 5 Replies
Print settings
What is the logic to have with the printing parameters, why is it possible to create several variants of the same parameter if it is not possible then to select it from the browser or the configuration window of the setup? The documentation on the "additive" part is scarce I find, where is it possible to find complete help on this subject?
Capture d’écran 2023-03-04 à 22.06.14.pngCapture d’écran 2023-03-04 à 22.06.43.pngCapture d’écran 2023-03-04 à 22.07.15.png
5 REPLIES 5
seth.madore
in reply to: mac_ito
I just went thru this myself on my Prusa printer. All I did was open the print settings on the Prusa Slicer on one screen and then created a new print setting in Fusion, copying all the values that I knew worked for PETG
Seth Madore
mac_ito
in reply to: seth.madore
yes thx seth but my question is why is it not possible to select presets from the browser?
mac_ito
Hi, Why does the name of the file appear rather than the name? Is this normal if so what is the logic?
Capture d’écran 2023-03-06 à 09.26.56.pngCapture d’écran 2023-03-06 à 09.27.08.png
mac_ito
it's good I found
Capture d’écran 2023-03-06 à 10.56.42.pngCapture d’écran 2023-03-06 à 10.57.07.png
mac_ito
