Preserve Order seems to be bugged
LibertyMachine
Mentor Mentor
LibertyMachine
Making a simple fixture for a part I've got coming up. All is going well enough. I go to make my deburring pass. I forgot to turn the compensation to Computer (I try to run deburr tools with no comp and control the edge break with tool height offset) I notice that the order in which features are deburred is not in the order I picked them. Odd. Go to look at the setting, and I've got Preserver Order selected. Hmm.
Set it to Computer (it was set to control) and it followed the order in which I selected features. Set it to Wear or Off and it behaves as expected.
TL/DR: Preserver Order isn't working (in this application) when comp is set to Control.
I've sent this into the Fusion team, just posting here to see if anyone has run into this
I've uploaded the .f3d. I had to delete out my customer part (NDA stuff) so that explains the sketch errors in model mode)
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
I have a similar issue (among others)  see my thread here
In my case it only follows the order in which I select them regardless of the check in preserve order or not for "in control"
For "in computer" I just get a crazy tool path....
Cheers
Chris
