Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Preload WCS coordinates
2 REPLIES 2
dbunyip
193 Views, 2 Replies
Has anyone got a better workflow for preloading the WCS coordinates from within fusion. Running a pallet pool machine, multiple parts per pallet. Pallets are all set in a known location. I've been doing it now, manually measuring all the parts and entering all the positions into the code by hand. This is pretty slow and has a high chance of fat fingering a number somewhere. Currently the only automation I've been able to come up with is using excel to pattern out the WCS macro variables for Z as they are all the same.
2 REPLIES 2
programming2C78B
in reply to: dbunyip
outside of sketching them, I'd just make a Pass through that you write properly one time and save as a template.
Please click "Accept Solution" if what I wrote solved your issue!
da_fish
If you are measuring each part and moving the WCS based on your measurement, then the only way to get around manual data entry would be using a probe.
But if you are always setting the WCS to the same place then you I would recommend writing a program and storing it on the machine. I run a machine with a table changer and each table is setup with Lang style plates and and in the center of each square pattern I have two WCSs:
I made a program that sets all the WCSs back to default. This program can be run on the fly if needed or between setups with MDI. All I need to do is run a program call (M98 P9999).
I hope this gives you some good idea's.
