Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Preload WCS coordinates
dbunyip
dbunyip
Has anyone got a better workflow for preloading the WCS coordinates from within fusion. Running a pallet pool machine, multiple parts per pallet. Pallets are all set in a known location. I've been doing it now, manually measuring all the parts and entering all the positions into the code by hand. This is pretty slow and has a high chance of fat fingering a number somewhere. Currently the only automation I've been able to come up with is using excel to pattern out the WCS macro variables for Z as they are all the same.
programming2C78B
outside of sketching them, I'd just make a Pass through that you write properly one time and save as a template.
Please click "Accept Solution" if what I wrote solved your issue!
da_fish
If you are measuring each part and moving the WCS based on your measurement, then the only way to get around manual data entry would be using a probe.
But if you are always setting the WCS to the same place then you I would recommend writing a program and storing it on the machine. I run a machine with a table changer and each table is setup with Lang style plates and and in the center of each square pattern I have two WCSs:
I made a program that sets all the WCSs back to default. This program can be run on the fly if needed or between setups with MDI. All I need to do is run a program call (M98 P9999).
I hope this gives you some good idea's.
