Fusion Manufacture
Preload tool position
9 REPLIES 9
Message 1 of 10
stefano.oteri
311 Views, 9 Replies
Goodmorning,
I would like to ask you for some advice. We need to set the change of position near/by the preolad tool to make the input of the manual tool easier. Can it be added in the post processor? Thank you. Have a nice day
9 REPLIES 9
Message 2 of 10
DarthBane55
in reply to: stefano.oteri
It most likely can be done.  I moved the prep tool call in a few of my posts.  However, in order for someone to really know what you exactly want, can you put a short section of code, what you have right now, and what you want after the change?  That would go a long way in understand exactly your need.
Message 3 of 10
stefano.oteri
in reply to: DarthBane55
Good morning,
now i have this program, for example:
N135
T42 M06
M01
T34
S400 M03
G54
M11
G00 B315.
M10
G00 X0. Y46.
G43 Z229.156 H42
G00 Z219.156
G83 X0. Y46. Z39.536 R170. Q3. F45.
G80
Z229.156
M01
M05
G91 G30 Z0.
G90
G49
The program I want is this:
N135
T42 M06
G00 X-400 Y500
M01
T34
S400 M03
G54
M11
G00 B315.
M10
G00 X0. Y46.
G43 Z229.156 H42
G00 Z219.156
G80
Z229.156
G00 X-400 Y500
M01
M05
G91 G30 Z0.
G90
G49
Thank you, have a nice day
Message 4 of 10
Good morning!
Could someone kindly help me to modify the post processor about this issue for which we already asked for advice?
Message 5 of 10
What post processor are you using? I would also recommend having that G0 XY position be relative to the machine co-ordinate system, rather than the current WCS.
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
Message 6 of 10
Thank you @GeorgeRoberts .
Our default post processor is "Doosan 3/5-axis VMC (FANUC)". Our goal is to have the movement before the M01 code as close as possible to the inspection door.
Message 7 of 10
Thank you. To do this, you will need to add some code to the post processor slightly before this line (at around line 1732):
    if (!isFirstSection() && getProperty("optionalStop")) {
 The code you would want to add is this:
    if(!retracted){
      writeRetract(Z);
    writeBlock(gAbsIncModal.format(0), gFormat.format(91), gFormat.format(30), xOutput.format(-400), yOutput.format(500))
    writeBlock(gFormat.format(90));
(update the co-ordinates to be the values you want). Again, I would recommend doing it this way instead of just a G0 move.
After the modification, the code should look like this
  if (insertToolCall) {
    activeCoolants = []; // force coolant on tool change
    forceModals();
    forceWorkPlane();
    setCoolant(COOLANT_OFF);
    if(!retracted){
      writeRetract(Z);
      onCommand(COMMAND_OPTIONAL_STOP);
George Roberts
Message 8 of 10
Good morning, thank you @GeorgeRoberts .
I tried to enter the code you suggested, but now I find that the line "g00 x-400 y500" appears with every operation, while we would like this movement to occur only when the m01 code is present. Is it possible to do this?
Thank you very much.
Message 9 of 10
Yes, you could move it into the optional stop if statement below. I'm surprised it appears with every operation, if you placed it in the correct location, it should only appear when a toolchange is needed.
Can you share the post processor you modified?
George Roberts
Message 10 of 10
Attached is the post processor you requested. Thank you.
