Fusion Manufacture
pre drill position unusable error.
3 REPLIES 3
mayuranMH5RH
128 Views, 3 Replies
Trying to do 2D pocket operation using predrill position for plunge in to the pocket, but fusion does not allow me to use the drill position, says " drill position is unusable". I have 4 same pockets on the piece it does 3 of them only for 1 pocket its giving me the error.
3 REPLIES 3
seth.madore
in reply to: mayuranMH5RH
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
If the pockets are actually identical, program one and pattern it.
Please click "Accept Solution" if what I wrote solved your issue!
mayuranMH5RH
in reply to: seth.madore
I need to get permission for that. and my boss is on holidays for this week.
