Fusion Manufacture
PP for DVF 6500 with TNC 640
4 REPLIES 4
a.hosniB5HV5
228 Views, 4 Replies
Kindly I'm looking for the postprocessor in the library which could match our Doosan DVF 6500 5-Axis with Heidenhain TNC 640 controller. Any recommendations ?!
Thanks in advance.
4 REPLIES 4
seth.madore
in reply to: a.hosniB5HV5
It does not appear that we have a post written for that machine. We have a Doosan 5 axis post, but it's written for a Fanuc machine. Furthermore, it also doesn't look like we have one fore a TNC 640 controller. I would advise you to partner with one of our resellers and have a custom post written for you. You can find a list here
Seth Madore
a.laasW8M6T
The standard Heidenhain post is suitable for TNC640 controls:
But I agree with Seth, you would be best to get a custom post made, there will likely be machine specific cycles and M codes that are not in the Standard Heidenhain post
Generally speaking 5-axis heidenhain machines will run on stock posts if the axis configuration is setup correctly.
There might be some machine builder specific cycles you could add. But getting Fusion running with the machine shouldn't be hard at all.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
a.hosniB5HV5
Thank you all for your guidance.
