Fusion Manufacture
PP Fanuc doosan milling / Post properties / Safe retracts to Clearance Height
4 REPLIES 4
deniss_nossikovZW2YC
106 Views, 4 Replies
I use PP from Fusion library -  doosan vmc fanuc.cps
only two option available - G28 and G30
but i want to have - Clearance height
How can I do it?
In PP we have
when I just remove // -  the postprocessor doesn't work
4 REPLIES 4
Remove the two // and you should be able to choose that option while posting
when i select "clearance height" i get an error
Are you working on a multi axis machine? Then it won't work i guess.
/** Output block to do safe retract and/or move to home position. */
function writeRetract() {
  var words = []; // store all retracted axes in an array
  var retractAxes = new Array(false, false, false);
  var method = getProperty("safePositionMethod");
  if (method == "clearanceHeight") {
    if (!is3D()) {
      error(localize("Safe retract option 'Clearance Height' is only supported when all operations are along the setup Z-axis."));
    return;
/** Disables length compensation if currently active or if forced. */
function disableLengthCompensation(force) {
  if (lengthCompensationActive || force) {
    validate(retracted, "Cannot cancel length compensation if the machine is not fully retracted.");
    writeBlock(gFormat.format(49));
    lengthCompensationActive = false;
3 axes machine
