Postprocessor - Simply read of coolant table?
justontour
justontour
i´m currently looking for a simply way to read the variables from the coolant table:
Today i use the old method to read the first two coolant states from the tool (Flood and Mist) and activate them with M8 and M10:
var mapCoolantTable = new Table(
  [9, 8, 10],
  {initial:COOLANT_OFF, force:true},
  "Invalid coolant mode"
var c = mapCoolantTable.lookup(tool.coolant);
    if (c) {
      writeBlock(mFormat.format(c));
    } else {
      warning(localize("Coolant not supported."));
Now i looking for simple method to read the var c from the "new" cooland table method (here from the fanuc pp):
var coolants = [
  {id:COOLANT_FLOOD, 8},
  {id:COOLANT_MIST,  10},
  {id:COOLANT_THROUGH_TOOL, 41},
  {id:COOLANT_AIR, 42},
  {id:COOLANT_AIR_THROUGH_TOOL, 43},
  {id:COOLANT_SUCTION, 44},
  {id:COOLANT_FLOOD_MIST, 45},
  {id:COOLANT_FLOOD_THROUGH_TOOL, 46},
  {id:COOLANT_OFF, 9}
How do i have to adapt the Var c line to read from the var coolant array my numbers as output?
Best case would be something like this to have a easy read function:
var c = mapcoolantsArray.lookup(tool.coolant)
Thanks for help.
Replies (0)
