Fusion Manufacture
Postprocessor 3D printing
8 REPLIES 8
Message 1 of 9
fjellang
320 Views, 8 Replies
I have used Fusion 360 and Postprocessor for Anet A8 for years with very little trouble. With new 3D printer Flash Forge Adventurer 4 it is trouble. When filament should go out it goes in. Motor runs wrong direction. Same component is used for both tests. What is wrong.
8 REPLIES 8
Message 2 of 9
serge.quiblier
in reply to: fjellang
Hello @fjellang
this is strange.
I don't really see a reason for this behavior, can you share the gcode generated by Fusion?
Looking at the code, I may find a cause.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
Message 3 of 9
fjellang
in reply to: serge.quiblier
Hello
Try once more to send the file. Hope it is ok.
Message 4 of 9
serge.quiblier
Hi @fjellang
I looked at the file, and i did not see anything shocking.
The E value seems to be correct. There is some few value negative, But it's always E-0.5, the small retract before a skim moves.
So, nothing strange.
But you can try by switching to absolute filament mode by unchecking a switch in the post properties:
Can you try to generate a gcode in absolute mode and test on the printer, please?
Regards.
Serge.Q
cam.autodesk.com
Message 5 of 9
fjellang
Works well when unchecking relative extrusions mode.
Thank you.
Message 6 of 9
thomas.stock
Hi @fjellang ,
So that we can also get relative extrusion working for the Flashforge printers in the future, could you please assist use with testing the following gcode file.
The ONLY change that has been made form your original file that you uploaded here, is that the 'M83' command has been placed after the 'G90' command:
This is because we believe the G90 command was overwriting the M83.
I attach this edited gcode file to this message.
Many thanks for your help!
If my answer has helped you, then please click "Accept Solution"
If not, feel free to reply back and tag me
Tom
Fusion 360 Additive Team
Message 7 of 9
fjellang
in reply to: thomas.stock
Hi Thomas
Your solution Works well, tested and ok
regards
Message 8 of 9
serge.quiblier
Hi All,
some posts had been modified to avoid this issue.
The Dremel, FlashForge and Re3D posts are now fixed and available online.
Thanks for reporting the issue and help us test and validate.
Regards.
Serge.Q
cam.autodesk.com
Message 9 of 9
thomas.stock
Hi @fjellang ,
Yes your testing has been extremely useful! We've now corrected several FFF posts as mentioned by Serge.
Thanks again,
Tom
