Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
POST Processors for 4 axis CAMASTER?
3 REPLIES 3
Madcow2
294 Views, 3 Replies
Does any one have a working post processor for a CAMASTER  4 axis?  With out the post processors all of the CAM rotary tool paths are useless.
3 REPLIES 3
daniel_lyall
in reply to: Madcow2
The one here seems to have it in the machine config https://cam.autodesk.com/hsmposts?
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Madcow2
in reply to: daniel_lyall
I could be wrong .... but that is the working one for 3 axis.  It is the same problem.  I am looking for the post processor that can also do 4th axis. The machine manufacture does not want to do it, wincnc does not want to do it and Fusion 360 does not want to do it but they will make software that can do the tool path.  What good is it if you can not get it to the machine.  I will keep on posting and maybe some one out there is working on it.  Aspire software can do it so why can't Fusion 360 get the post process for all machines done before they make the tool that can do the tool path????  Even though it is a great piece of software... again if you can not use it for real manufacturing processes it is not really helpful.....
Thanks for the link
It is up to the user or Machine Maker/ control maker to have posts available for there machines, not Autodesk.
Have you searched to see if you can find one?
You may need to pay someone to do it for you, it is not a simple exercise to get it done there is a lot of work involved in doing it.
One thing you can try is to try the Fanuc post (Fanuc fanuc.cps)to see if this helps.
