Fusion Manufacture
Post Processor z height problem
2 REPLIES 2
david
131 Views, 2 Replies
Hi
Im using Fusion 360 personal use with UCCNC for a Stepcraft D840 Machine and all of a sudden have been having tremendous problems with the Z Height, it started going down in depths further that the stepdowns then the last time I tried it went right through the stock and the waist board, I can only think I have a setting wrong, any advise ?
Regards David
2 REPLIES 2
seth.madore
in reply to: david
This could be a machine or a post issue. Would you be able to share your Fusion file here or privately?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply. To share the file privately, it's the same process, but email it to me: seth DOT madore AT autodesk DOT com
Seth Madore
david
in reply to: seth.madore
Thanks for the rely Seth, it could well be a machine or post issue, the z just goes down to different depths, your inside though would be appreciated, thanks again.
David
