Fusion Manufacture
Post Processor Warning: "Warning: Unsupported variable specifier 'onchange'."
1 REPLY 1
thomas.fiermans
153 Views, 1 Reply
When posting a program I get a warning: "Warning: Unsupported variable specifier 'onchange'."
This only happens when I choose in the Post Processor menu: Use Subroutines: Patterns
This happened with the previous versions of the Haas NGC post Processors aswell.
As it is a Warning it isn't anything major but I still wanted to note it. It seems similar to the the bug this user found:
https://forums.autodesk.com/t5/fusion-360-manufacture/warning-unsupported-format-specifier-inherit/m...
Labels (1)
1 REPLY 1
Thank you for report!
As I see, onchange handler does not work in incremental variables actually.
And it is a real bug, rather than wrong warning for inherit property. We need to fix it.
Viacheslav Shapilov
Developer Technical Services
Autodesk Developer Network
