Post Processor - Stepcraft
Hi everyones,
I just bought a Stepcraft CNC with HD Spindle and the laser head. This CNC geek world is totally new for me but I already love it !
There is a lot of informations to understand for a newbie like me, especially about the workflow (and good practices) from the drawing to the cutting or milling.
At this point everything seems to be clear : I modeling then generating a toolpath in Fusion 360 who will give me a G-code file to load in UCCNC.
But I have a problem for generating the toolpath in Fusion 360.
If I correctly understand I have to load Post Processors in Fusion (who is a kind of tool library, right ?), but I can't find how to correctly achieve that. I do exactly what they said here but the Stepcraft tools don't appear in the list when I create a 2D contour path in the CAM section from Fusion 360.
Someone can please explain me ? am I have wrong somewhere ?
Thanks !
Matthew-R
@Anonymous Thanks for submitting your question to the forum.  If you've followed the article that you linked, your posts should be showing up for you.  I created a quick Screencast hopefully explaining a bit more about post locations.  Also, make sure that the file extension was maintained as a .cps because if it has changed, it would not show up in the list.  Thanks again and let me know if this issue is still persisting.
Here's another important link you're most likely aware of, our post processor library where you'll find that Stepcraft CNC post.
Autodesk Post Processor Library
Screencast
