Fusion Manufacture
Post processor selection
2 REPLIES 2
paultomlinson5
183 Views, 2 Replies
Could someone please explain to me step by step how to select and use a post processor. I have created a tool path in the manufacturing part of fusion 360, I now want to generate the g code for Tormach slant pro lathe using Pathpilot.
2 REPLIES 2
Create your toolpaths.
Click on "Post Process"
Select your post, you need to click here:
Select the post you need from the library: 
Copy it to a local or cloud folder:
 Note: in the image above, the "forum CPS files" is a local folder for me, you won't see that. Also, if you don't have Cloud Libraries turned on in your Preferences, you will also not see that as an option.
Seth Madore
Perfect, thank you.
