Fusion Manufacture
Post processor installation for Turn on Dynomotion control.
2 REPLIES 2
spancheau
113 Views, 2 Replies
Found this post in Dynomotion helps. By Alexander  (Anekcahap Ykpanheu)
Fusion 360_KFLOP_Turning_Rev2.cps.txt (Added thread cutting G32) dated 2012-2017 by Autodesk, Inc.
I asked Tom K at Dynomotion for for correct proceedure to install for use. He indicated he is not familiar with the post for Fusion, and suggested I contact this forum for help.
Thank You,
Scott
2 REPLIES 2
seth.madore
in reply to: spancheau
Are you asking how does one go about installing and using a post processor for Fusion?
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Seth Madore
spancheau
in reply to: seth.madore
Thank you for your response. I realized my thinking was wrong. I was able to get the post downloaded and installed within my posts in Fusion. The post seems to work well. I only had to change the G97 at start to G96 and add G99 before that.
