Post processor help: How to get WCS origin's X, Y and Z values
isamiBDSPX
isamiBDSPX
Hi everyone!
I'm having a little bit of trouble getting my post processor to write a simple line of code like:
G10 L2 P1 X0. Y0. Z-381.926 (G54 WCS)
That line, on a Fanuc control will set the G54 WCS.
In the part I'm working right now, the WCS origin on my setup is set at (X=0, Y=0, Z=-381.926)
When I dump the information I can get this:
currentSection.fcsOrigin=(1.7859e-13, 1.10939e-13, 381.926)
which are the X, Y and Z values that I'm looking for, well sort of.
I have three problems:
 1. I don't know how to access the individual values.
 2. Even though my WCS origin is at X=0 and Y=0, I get a scientific notation of a number that's very close to zero but not exactly zero (X= 1.7859e-13, Y= 1.10939e-13).
 3. I always get the values inverted. What I mean is that they are presented as if they are multiplied by -1. Why?
Any ideas on how to get my post to write this line of code?
G10 L2 P1 will always be the same, but the X, Y and Z coordinates will change whenever I change the WCS origin.
Thanks in advance.
Best,
Isami
seth.madore
Is it ALWAYS that same exact line of code?
Seth Madore
isamiBDSPX
G10L2P1 is always the same
but the X,Y and Z values depend on where I've established my WCS origin which changes on every part.
isamiBDSPX
I've found the solution. Once I've discovered the WCS is stored in a Vector Object everything was very straight forward.
This is the code I needed:
  var setupWCSorigin = getSection(0).fcsOrigin.negated;
  var setupWCS = getSection(0).workOffset;
  gAbsIncModal.reset();
  writeBlock(
    gAbsIncModal.format(90),
    gFormat.format(10),
    "L2P" + (1 + setupWCS),
    "X"+xyzFormat.format(setupWCSorigin.x),
    "Y"+xyzFormat.format(setupWCSorigin.y),
    "Z"+xyzFormat.format(setupWCSorigin.z),
    formatComment("G" + (54 + setupWCS) + " WCS")
  writeBlock(gFormat.format(11));
 The vector object logically has the x, y and z attributes, problem 1 solved.
 xyzFormat takes care of the scientific notation, problem 2 solved.
The vector object also has the negated attribute which, as its name implies, gives you the negated vector, problem 3 solved
With that code, on a FANUC control, I can have the program update automatically the WCS.
For example:
G90 G10 L2 P2 X56. Y-284. Z-395.926 (G55 WCS)
This will update the G55 WCS to those coordinates which is the origin of my Setup. You can update other WCS changing the P value. (P1 = G54, P2 = G55, P3 = G56, P4 = G57, P5 = G58, P6 = G59)
I found this very useful to have a relatively accurate position of the WCS before probing the part to have the exact location of the WCS.
Hope this can help others!
Cheers,
Isami
