Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
[Post Processor, Heidenhain] Cycl call after coolant off
12 REPLIES 12
Message 1 of 13
mbl_busse
677 Views, 12 Replies
Hey there folks,
I want to optimize the pp for our C52 a bit further.
Before a toolchange happens I want to 'clean' the remaining coolant from the coolant-jets or the tool by blowing it out with air.
With normal flood coolant this is no problem- Hermle added a M-Code wich does exactly this (M440).
But for through-tool coolant there is only a cycle: cycle 315.
Therefore I have to add a cycl def after setting throughTool coolant off.
It has to look like this:
CYCL DEF 315 IKZ WZ ausblasen
Q1505=+2 ;Zeit ausblasen
Does anyone know how I could achieve this?
line from my pp, M440 already added, works flawless:
var coolants = [
{id: COOLANT_FLOOD, on: 8, off: [9, 440]},
{id: COOLANT_THROUGH_TOOL, on: 51, off: 52},
{id: COOLANT_AIR, on: 7, off: 9},
{id: COOLANT_AIR_THROUGH_TOOL, on: 12, off: 9},
{id: COOLANT_OFF, off: 9}
Thanks in advance and stay safe!
Janick
Tags (2)
Labels (1)
12 REPLIES 12
Message 2 of 13
jedQB94J
in reply to: mbl_busse
something like this will do the job.
Jacob
Message 3 of 13
mbl_busse
in reply to: jedQB94J
Hey there Jacob,
this is quite a good start, thank you very much.
So I got it working on pgm-end by writing it like this:
But this code doesnt work in case of a toolchange. I think the problem here might be that the currentCoolandMode is set earlier. Is there a way to 'grab' the coolant wich is currently running? In this case he seems to already take the coolandMode from the next tool..
Message 4 of 13
jedQB94J
Do the same in OnSection.
Jacob
Message 5 of 13
mbl_busse
Thats exactly the line I've inserted the code.. It's still the same thing.
If I go like you stated
[if (COOLANT_THROUGH_TOOL)]
the command will be executed with every toolchange- independent of the actual coolant.
If I go like
[if currentCoolantMode == COOLANT_THROUGH_TOOL]
the code will show if the NEXT tool hast TroughToolCoolant.
I attached my post, if you want to take a look..
Message 6 of 13
jedQB94J
Yes sorry, you need this condition.
Jacob
Message 7 of 13
mbl_busse
Hi Jacob,
thanks for all your help, but I just cant get this to work. Even not with the PP from your last post..
I tried several iterations of this code. I'm sure it's just a small thing, but something is missing here.
Greetings from Germany 🙂
Message 8 of 13
jedQB94J
Will you share a project where you have the fail?
Message 9 of 13
mbl_busse
Sure thing! It's just a file I tinker around for different ToolChange-Scenarios, because the NC-Extension of VisualStudio has no setting for something like M51-Toolchange-M8-Toolchange-M51 etc.
https://a360.co/2NsMsQ4
Here you go.
I also attached the NC-Program I get when PPing this through your PostProcessor. (changed to .txt for upload)
Message 10 of 13
jedQB94J
Now I thing it works:-)
Jacob
Message 11 of 13
mbl_busse
Ha, Jacob!
This seems to work. Very nice! Thank you very much. This was infact quite educational 🙂
One small issue seems to be, that now the cycl is also added to the first tool call. But thats really just a minor issue.
Thank your very much! 🙂
Message 12 of 13
jedQB94J
You welcome:-)
Here you go.
Message 13 of 13
mbl_busse
Flawless! :):)
