Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Post Processor for Thermwood 3 axis
0 REPLIES 0
Message 1 of 1
1088 Views, 0 Replies
Here is a post processor that I modified for Thermwood 3 Axis Routers. It is based on the default post available in the Fusion 360 library. Modifications include the option of using the pop-up pins, and eliminating the M48 code, which overrides the rapids with feed rate knob.
When posting with this processor, you will be prompted to press cycle start to raise pop ups, and again to lower. Rapids will not be controllable with feedrate, but cutting motions will. This more closely mirrors the output from Thermwoods control nesting.
Please use at your own risk, and test thoroughly. I have tested it on our machine, but am not responsible for your operations.
0 REPLIES 0
