Fusion Manufacture
Post processor for Syntec 60CB controller
2 REPLIES 2
mechanical1ineo
385 Views, 2 Replies
We're switching from Mach3 to a Syntec 60CB controller. We use Mach3Mill post processor to generate the g-code for our Precix routers. So, I was wondering what would be the equivalent post processor for the 60CB controller in fusion 360.
Labels (1)
2 REPLIES 2
engineguy
in reply to: mechanical1ineo
@mechanical1ineo
What is the machine configuration, is it just a 3 Axis, 4 Axis, 5 Axis ??
There are a few Syntec Post Processors that may work for you, I have attached a couple below, one is a straight Generic 3 Axis and the second is a modified one for 5 Axis.
With a bit of luck they should be a good starting point for you, post back if you find that there any "tweaks" needed to get them just right for your machine control.
mechanical1ineo
in reply to: engineguy
It is a 3-axis machine. There is a generic SYNTEC post processor file in fusion. I was just wondering if the 3-axis file that you sent is the same as that? I'll try both of them and see how it goes. Thanks @engineguy
