Fusion Manufacture
Post Processor for Leadwell CNC milling and turning
4 REPLIES 4
neelsMWJUV
140 Views, 4 Replies
Good day,
I am in need of a post processor for a leadwell CNC milling and turning machines.
If anyone can help me it would be much appreciated.
Machines are the following:
Leadwell CNC Lathe (T-7A)
Leadwell CNC Lathe (LTC-200)
Leadwell CNC Mill (V-30IF)
Leadwell CNC Mill (V-32IF)
Thank you.
4 REPLIES 4
seth.madore
in reply to: neelsMWJUV
Are those Fanuc based machines? We don't have any specific post processors for those, so I would point you in the direction of a similar machine and control. For milling:
1) I'd likely start with the Doosan or Fanuc post
For Turning:
2) Fanuc Turning or a Samsung/Doosan Turn/Mill post (if your machines have C/Y ability)
Edits are going to be needed.
Seth Madore
neelsMWJUV
Thank you.
The machines run off Siemens Software, I run the Siemens 810D post processor currently, it is working but I am not able to preview the machining on the Mill prior to startup. Thank you, I will try the Doosan first as recommended.
seth.madore
If they are Siemens based machines, you're going to need to use the Siemens post. A Fanuc based post is not going to give you the code you need.
Seth Madore
AdamKunzo
Hello @neelsMWJUV
I sent you a private message about. Let me know if you need a help  with these post processors.
