Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Post Processor for Leadwell CNC milling and turning
4 REPLIES 4
neelsMWJUV
180 Views, 4 Replies
Good day,
I am in need of a post processor for a leadwell CNC milling and turning machines.
If anyone can help me it would be much appreciated.
Machines are the following:
Leadwell CNC Lathe (T-7A)
Leadwell CNC Lathe (LTC-200)
Leadwell CNC Mill (V-30IF)
Leadwell CNC Mill (V-32IF)
Thank you.
4 REPLIES 4
seth.madore
in reply to: neelsMWJUV
Are those Fanuc based machines? We don't have any specific post processors for those, so I would point you in the direction of a similar machine and control. For milling:
1) I'd likely start with the Doosan or Fanuc post
For Turning:
2) Fanuc Turning or a Samsung/Doosan Turn/Mill post (if your machines have C/Y ability)
Edits are going to be needed.
Seth Madore
neelsMWJUV
Thank you.
The machines run off Siemens Software, I run the Siemens 810D post processor currently, it is working but I am not able to preview the machining on the Mill prior to startup. Thank you, I will try the Doosan first as recommended.
seth.madore
If they are Siemens based machines, you're going to need to use the Siemens post. A Fanuc based post is not going to give you the code you need.
Seth Madore
AdamKunzo
Hello @neelsMWJUV
I sent you a private message about. Let me know if you need a help  with these post processors.
Technology Administrators
