Fusion Manufacture
post processor for fangling cnc plasma
6 REPLIES 6
krisB7MZE
723 Views, 6 Replies
im looking for a post processor for a fangling cnc plasma. Now im using fastcam.
The baileigh processor is close but it dosn't work. Does anyone have a idee to change the post processor?
first one is the code by fusion, the second one is made by fastcam
Any help is welcome
g code made by fastcamg code made by fastcam
6 REPLIES 6
serge.quiblier
in reply to: krisB7MZE
Hi @krisB7MZE
you can try this post, created from a similar request on another category of the Fusion forum.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
Boopathi Sivakumar
Senior Technology Consultant
krisB7MZE
in reply to: serge.quiblier
thanks for that processor. It creates a false line but for the rest it works. I also fond the hycut processor that works.
Fastcam uses G40,G41 and G42 as gap compensation. The fanling and hycut doesnt' use that. How can i put that in?
regards
serge.quiblier
Hello @krisB7MZE
Did you set you machining correctly?
Because if I test myself, here is the toolpath definition
I green framed the parameters related to the cutter compensation settings.
Then the nc dialog for processing
I am using the post provided, and I am generating a program called 8596.
and the final result is :
So, G41/42/40 appears, alone on a line, but they are outputted.
Do they need to be on the same line as the move????
Cheers.
Serge.Q
cam.autodesk.com
krisB7MZE
Hey,
thanks for the tip. My problem is solved.
regards
urielrg
Hi, I'm struggling on the configuration for my fangling f2100b, is there any way you can help me please?
I will really appreciate your help.
