Post Processor for Doosan Puma V550M
afalzate
afalzate
I have a vertical lathe with a Fanuc 21i-5B controller. I was hoping to use the Fanuc turning post processor, or the Doosan Mill/Turn PP, but it either fails or doesn't create Gcode exactly like proven older code. If anyone else has accomplished this it would be immensely helpful, otherwise I would appreciate some guidance whether someone has an idea of modifying the generic Fanuc processor, or trying to get the Doosan PP that was meant for another controller to work with mine.
serge.quiblier
Hi @afalzate
can you share more information's, please?
Do you have an error on the controller? On which code?
Do you know that Fanuc controllers can use one of three differents g code flavors?
This can be set via a post property:
Depending on the flavor selected, some G-code are differents for a command.
CommandType AType BType C
feed per minute G98 G94 G94
spindle speed limit G50 G92 G92
threading G92 G78 G21
multipass threading G76 G76 G78
It can be the issue.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
