Post Processor fails to output
bjw9EQBR
Observer
bjw9EQBR
Observer
Observer
Just recently I have attempted to output nc code using a post processor from the Fusion library that I have successfully used many times.  I get an error message that says it failed to post.  The error message further says :
Error: ReferenceError: createOutputVariable is not defined
Error at line: 179.    I also saw under job status that an update failed to complete.  Can you offer some suggestions how to resolve?  Thanks.
seth.madore
What post processor are you using, and can you share your Fusion file? (it may be related to a toolpath setting)
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
As for the "Update Failed", you can click here:
If that doesn't solve it, you'll likely need to run the Fusion Service Utility
(likely not related to the issue you're seeing, but it's best to resolve this issue)
Seth Madore
bjw9EQBR
Observer
Observer
This is the f3d file attached.  I am using the Shopsabre with WinCNC post from the library.
bjw9EQBR
Observer
Observer
One additional detail-  I also tried to output single toolpaths at a time, not all of them and it didn't seem to make a difference.
AchimN
Hello @bjw9EQBR ,
I am pretty sure that you get this error because your Fusion installation is outdated but the postprocessor you are using does require Fusion to be updated to the latest version.
In detail, the latest Shopsabre postprocessor does require as a minumum the postprocessor kernel version 45917 and there is a good chance that your outdated Fusion is using an older version.
You can either try to get your Fusion updated so that it has the latest postprocessor kernel or you can use the previous version of the Shopsabre postprocessor which you can download here:
https://cam.autodesk.com/hsmposts?p=shopsabre
More information about post kernel/post script file versions:
https://forums.autodesk.com/t5/hsm-post-processor-forum/need-help-with-error-the-post-configuration-...
Achim.N
Principal Technology Consultant
bjw9EQBR
Observer
Observer
Thank you for the help. I will need to get a system administrator here to update my version.
