Fusion Manufacture
Post Processor Error
10 REPLIES 10
Message 1 of 11
dduplantis99
257 Views, 10 Replies
Hi everyone, I'm new to fusion 360 and I'm trying to post a process of a roughing canned cycle for a lathe. Every time I try posting it with the canned cycle option under the passes tab on, it fails to post. Once I turn it off it works fine. Is their something that I'm doing wrong or is this a known issue. Thanks
10 REPLIES 10
Message 2 of 11
seth.madore
in reply to: dduplantis99
You're using the Doosan post, it should support canned cycles. Could you share your Fusion file as well as the post processor you're using?
Seth Madore
Message 3 of 11
dduplantis99
I'm using the default Doosan post processor.
Message 4 of 11
seth.madore
Is it the most recent post? I'm getting this:
O1001
N10 G98 G18
N11 G20
N12 G50 S6000
N13 G28 U0.
N14 G28 W0.
(PROFILE ROUGHING1)
N15 T0101
(CNMG432)
N16 G54
N17 M8
N18 G99
N19 G97 S573 M3
N20 G0 X4. Z0.1969
N21 G50 S5000
N22 G96 S600 M3
N23 G0 Z0.02
N24 X2.04
N25 G71 U0.04 R0.04
N26 G71 P27 Q31 U0.02 W0.002 F0.016
N27 G0 X1.876 Z0.02
N28 G1 Z0.
N29 X1.906 Z-0.015
N30 Z-4.7742
N31 X2.
N32 G0 X4. Z0.02
N33 Z0.1969
N34 G80
N35 G97 S573 M3
N36 M9
N37 G28 U0.
N38 G28 W0.
N39 M30
Seth Madore
Message 5 of 11
engineguy
in reply to: seth.madore
@seth.madore
I get the same as @seth.madore using the same PP, you must have a different PP, see images below, first one is the code with the Canned Cycles shown and the second one is the area in the PP where the Cycles are generated, if your PP doesn`t have this then it won`t post the cycles.
Message 6 of 11
seth.madore
This seems relevant:
Seth Madore
Message 7 of 11
dduplantis99
I downloaded the updated Doosan Turning Post Processor off of the website and it has the same coding as the picture you shared but I'm still getting a failed post
Message 8 of 11
seth.madore
Please share your Fusion file here then, there may be something else going on.
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 9 of 11
dduplantis99
Message 10 of 11
seth.madore
Are you certain that you've selected the right post processor? I'm still getting perfectly valid code.
Also, have you updated Fusion lately (it's possible that it's tangentially related)?
Seth Madore
Message 11 of 11
dduplantis99
Since I'm just learning fusion i was using the hobbyist version of the software but I switched it to the 30 day free trial and it started posting fine how its supposed to. Sorry for all the headache!
