post processor choice
nick_brown_7
nick_brown_7
Hi every one,
which post processor should i use to output for a Mazak Vortex 815 running Fanuc 15i-M ?
any help is appreciated
cheers
nick
Marco.Takx
Hi @nick_brown_7,
In the link below you can search yourself for a post processor that fits your machine.
Haven't worked for that machine yet so I can't say which should work.
Search for Mazak or Fanuc and see if you find one that comes close.
HSM Post Processor Library
After that you can modify a post processor by your self (You need some JavaScript knoweledge) or go to a local resseler to let them help you.
In the link below you find a list of Resellers that can help you.
HSM post adjustments needed? Find your right contact here.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
nick_brown_7
hi Marco,
thanks for replying, but none of those seem suited. Forgot to say it's 5 Axis
cheers
nick
Marco.Takx
Hi @nick_brown_7,
Then I only can advise you to contact your local reseller.
In the link below is a list of resellers how can help you.
Marco Takx
