Fusion Manufacture
Post processor C+ working ok, C- seems to follow the rotation
11 REPLIES 11
Message 1 of 12
ryanYANVW
361 Views, 11 Replies
Hi, I've been using the Doosan post processor 3+2, I'm using a rotary pocket tool path on a DVF 6500 fanuc control. Everything is working ok in the C+ motion, but as soon as it tries to go to C- the tool/spindle seems to follow the rotation instead of staying central to the part and letting the bed do the rotations instead. (I've attached the video below, as I'm not quite sure how to explain it lol)
I've attached the post processor that I am using below also.
Many thanks,
Ryan
11 REPLIES 11
Message 2 of 12
ryanYANVW
in reply to: ryanYANVW
It seems to be changing the workplane as it rotates in the C- axis. Please help asap
Message 3 of 12
a.laasW8M6T
Hi
It's very difficult to tell what is going on without seeing the part file and toolpaths.
Would you be able to upload your file here?
It could be post related, what I see happening is maybe a linking move with TCP on thats not being executed properly.
Message 4 of 12
ryanYANVW
in reply to: a.laasW8M6T
Hi, I've uploaded the tool path and files below.
Thanks for your reply!
Message 5 of 12
a.laasW8M6T
What setting do you have here?
You will have 5 axis checked but do you have rotary scale checked?
Message 6 of 12
ryanYANVW
Message 7 of 12
ryanYANVW
Yes I have checked off the rotary scale, force IJK, G68.2 and 5th axis.
I did modify my latest post to reflect this.
Message 8 of 12
It seems like the machine does not have the shortest path enabled.
To verify when you call C axis to 359 in the mdi mode and the next line if you call Cto 1 deg if the C axis rotates just 2deg to reach the position then the machine is enabled with shortest path instead if it rewinds 358 back to reach the postion then the machine is not enabled with shortest path.
if it rotates back 358 deg then in the post you have to change the kinematics like this
  if (getProperty("fifthAxis")) {
    if (receivedMachineConfiguration) {
      error(localize("You can only select either a machine in the CAM setup or use the properties to define your kinematics."));
      return;
    var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-120.0001, 0], preference:-1, tcp:useTCP});
    var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], tcp:useTCP});
    machineConfiguration = new MachineConfiguration(aAxis, cAxis);
    setMachineConfiguration(machineConfiguration);
 and you have to disable the property while posting
This would make sure to output the C axis in linear way
Boopathi Sivakumar
Senior Technology Consultant
Message 9 of 12
It seems to have shortest path enabled, I put 359deg in MDI and then put 1deg into MDI. It went to 1 deg. Everything seems ok.
Do you think disabling the rotary scale will solve the issue?
Message 10 of 12
It's working now, i changed the post and removed rotary scale with you info you provided.
So we are getting somewhere now, but when the machine moves in G0 the table and head judder?
When its machining in G01 its ok, do you know how to solve this issue?
Message 11 of 12
Sorry for the delayed response may be when axis is moving in rapid it may not properly syncronized. you can try using the highFeed rate this will make sure always it outputs the rapid move with the G1 with the High feed rate value
Boopathi Sivakumar
Message 12 of 12
ryanYANVW
Yes, that's perfect thank you for your help!!
